I have a field with multiple comma separated values, like “item1, item2, item3…”.
I need to add to each of these values a prefix or a suffix obtaining a similar result “T_item1, T_item2, T_item3…”. Is it possible with your software solution?
Thanks in advance
just simple replace ", " by “, T_”.
This doesn’t add it for the leading first item. For this I would use a new column with the prefix “T_” move it in front of the other column and concat both.
Thanks a lot, it was easier than I thought ![]()
By the way, what function should I use?
Suffix1.transform (3.1 KB)
Thanks a lot Olaf! Very simple and effective!
I am also stuck on that issue but your knowledge is easy to understand. I hope I will not forget. I appreciate your support.
