Here is the file I found on net, but I don’t know if it is correct and honestly I don’t understand the data that contains in it, if this is how your file looks like, then it would be nice, if you could explain which field you are interested in it and what do they stand for. Or you could make changes in this sample file with dummy data and tell us your desired output.
Today I found this page with detailed information about the banking payment standards for Switzerland. It has some downloadable documents with information about the ISO2022 standard that is being implemented by the Swiss banks.
How is this going? No activity for a while, but seems like it could match some of my oproblems.
I tried to make some filters and renaming columns and output to a simpler layout with the files we get from the bank.
My trouble is that if I set up so it works, next file doesn’t have all columns as the one before, so my filters uses the wrong columns when I try again.
The filter doesn’t seem to connect to the columns I setup, it seems to the be the the order the columns is found.
Is it better to use CAMT53 or CAMT54?
My goal is to convert to a CSV that is accepted in our old system.
One suggestion: Sometimes it is better to use another tool to “normalize” the XML. I use XSLT (a W3C standard language for converting XML to XML and other formats) to isolate the elements and attributes that I need. Then I use EDT to isolate/modify the data because now it is in a consistent format.
I downloaded the sample camt053 XML to play with. Can you post a sample of the CSV output that you are looking for? Thank you.
Concat makes the column in the picture before, I need to put two columns together since our invoice number is in different fields depending on sending customer.
And I also discovered that the camt54 is better/easier for me to use.
I am doing some analysis on your XML file. You have 7 Ntry elements and 19 TxDtls elements. It seems like you would need a row in your CSV file for each TxDtls element, correct?
