Is it possible to filter between to dates. For example I want to filter between 11/1/20201 and 3/1/2022. Thanks
Yes.
But you have to be careful that Easy Data Transform correctly infers whether it is month-day-year or day-month-year. It should have no problem doing that if is plenty of data. But, to be sure, you can put the preferred format first in Preferences.
