Hi, I have made a sample sheet of what I’m doing. However the real version has 54 columns to match up and 3072 rows. I can do each column using the lookup each column separately however I thought there might be a better quicker way that I was overlooking. I have to do this ever few weeks and I never seems to work twice the way I’m doing plus I have to merge everything.
I need to match up
Column A with Column I & J then get a Dates1 output
Column B with Column I & J then get a Dates2 output
Column C with Column I & J then get a Dates3 output
The output can be any name or a name the program generates. I can rename them to watch I want. It that number1 matches Date1, number2 matches date2, etc…
If not, that is fine. I felt it was worth asking
Kim
